Ca c'est fait
+12
m302
starsky
Merkurat's
CAM86
Fvcad
16 participants
Page 10 sur 19
Page 10 sur 19 • 1 ... 6 ... 9, 10, 11 ... 14 ... 19
Re: Ca c'est fait
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=18323#options
encore un
va falloir que j'achete aussi une mega etagere pour mettre chez john
encore un
Re: Ca c'est fait
Alors la j'ai peter un plombs
p'tite commande
QTY Model Number Product Name/Description
1 1405 Carburetors, Performer Carbs By Edelbrock
1 20416 Torque Converters - B&M Hole Shot 2000 - HoleShot 2000 Series
1 7101 Intake Manifolds, Performer RPM By Edelbrock - Manifold
1 141-758 Dress-up Kit - High-Tech GM Collector's Series
1 10-010 Hays performance Flexplate - Chevrolet SB Internal Balance 168 Tooth
1 EK1901
Chevy 350 Complete Street Performance Engine Kits - EK1901
Options For: EK1901
RINGS: .030
PISTONS: .030
CAM: CS1028R 214/214 DUR @ 50 .443 .443 LIFT LOBE 112
OILPUMP: MELLING RACING PUMP #10555
B&M 30228 - B&M Transpak Kits
Shift Kit, Transpak, GM, TH350, TH375B, M38, Each
Part Number: BMM-30228
Edelbrock 8722 - Edelbrock Carburetor Spacers
Spacer, Carburetor, 1/2 in. Thick, Wood Fiber Laminate, Divided Plenum, Square Bore, 4-Barrel, Each
Part Number: EDL-8722
Fram FV184 - Fram PCV Valves
PCV Valve, OEM Replacement, GM, Each
Part Number: FRM-FV184
Fram G3727 - Fram Fuel Filters ( ca s'est pour le blazer )
Fuel Filter, Asuna, GM, Isuzu, Jaguar, Land Rover, Passenger Car, Pickup, SUV, Van, Each
Part Number: FRM-G3727
R&M Specialties 1101-90-P - R&M Billet Wire Looms
Ignition Wire Loom/Separator, Vertical, Aluminum, Polymer, Polished/Black, 7-9mm, Chevy, Small Block
Part Number: RNM-1101-90-P
Spectre Performance 2369 - Spectre Performance Inline Clearview Chrome Fuel Filters
Fuel Filter, Inline Mount, Clear/Chrome, 1/4 in., 5/16 in., or 3/8 in. Inlet/Outlet Hose Barb Adapters, Each
Part Number: SPE-2369
Summit Racing SUM-174000 - Summit Racing Valve Spring and Retainer Kits
Valve Springs, Retainers, Single Springs, Steel Retainers, Locks, Single Groove, Seals, Chevy Small Block, Kit
Part Number: SUM-174000
Summit Racing SUM-360160 - Summit Racing Thermostats
Thermostat, Stainless Steel, Copper, Brass, 160 Degree, High-Flow, Each
Part Number: SUM-360160
Summit Racing SUM-371101 - Summit Racing Aluminum Water Necks for Chevrolet
Water Neck, Cast Aluminum, Polished, O-Ring, 90 Degree, Chevy, Big/Small Block, Each
Part Number: SUM-371101
Summit Racing SUM-G1419 - Summit Racing Carburetor Linkage Plates
Throttle Cable Bracket, Steel, Chrome, Holley, Edelbrock, Carter, Each
Part Number: SUM-G1419
Summit Racing SUM-G3090 - Summit Racing Chrome Gas Line Kits
Carburetor Feed Line, Steel, Chrome, Fits Carter, Edelbrock, Each
Part Number: SUM-G3090
Summit Racing SUM-G6905 - Summit Racing Roller Rockers
Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.5 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, Set of 16
Part Number: SUM-G6905
Taylor Cable 76230 - Taylor Spiro-Pro Race-Fit Spiro-Wound Core Spark Plug Wire Sets
Spark Plug Wires, Spiro-Pro Race-Fit, 8mm, Red, 90 Degree Boots, Chevy, Small Block, Under Headers, Set
Part Number: TAY-76230
Chevy Monte Carlo 1981 1982 1983 1984-1988 Car Cover n4
1979 80 81 82 83 Monte Carlo 11" Slotted Brake Rotors
1976 77 78 79 80 81 Monte Carlo Ceramic Exhaust Headers
Chevy 50K Volt HEI Distributor BBC SBC 283 305 350 400
GM 7.5 3.23 Ratio Ring And Pinion & Master Kit Package
GM 7.5 10 BOLT AUBURN POSI GM CHEVY 7.5 26 SPL 3.23 UP
quelle dimension pour le nouveau garage pour stocker les pieces john
je crois que j'ai presque tout
p'tite commande
1 EK1901
Options For: EK1901
RINGS: .030
PISTONS: .030
Re: Ca c'est fait
http://cgi.ebay.com/ebaymotors/1985-MONTE-CARLO-SS-BARN-FIND-93K-MILES-NEEDS-TLC-FLA-/150468507452?cmd=ViewItem&pt=US_Cars_Trucks&hash=item23089f373c
http://cgi.ebay.com/ebaymotors/1987-CHEVROLET-MONTE-CARLO-SS-AERO-COUPE-NO-RESERVE-/160457902108?cmd=ViewItem&pt=US_Cars_Trucks&hash=item255c09481c
http://cgi.ebay.com/ebaymotors/1984-CHEVY-MONTE-CARLO-SS-ORIGINAL-BOX-CHEVROLET-NEEDS-/230500920138?cmd=ViewItem&pt=US_Cars_Trucks&hash=item35aaeceb4a
Re: Ca c'est fait
oui pas cher
mais pas 30 ans donc homologation obligatoire,drire , utac , transport, douane , .......
et puis la mienne seras exactement comme je l'imagine
Re: Ca c'est fait
http://images.thetruthaboutcars.com/2008/10/homer-car.jpg
Re: Ca c'est fait
maya.bz a écrit:oui pas cher
Bizarrement c'est exactement ce que je pensais
Bien que ce que nous montre buickstate est clairement exacte (ces véhicules ne valent guère là-bas), lorsqu'il faut les importer et les remettre en état il vaut mieux immédiatement les modifier "à sa guise " car au moins on aura quelquechose d'unique et qui NOUS plait.
Je me contredis peut-être par rapport à MA croisade contre le "tuning" sur les ricaines (leurs faisant perdre toute leur valeur), mais cela ne concerne que les collector's . Les véhicules "banaux" peuvent très bien être "adaptés"
Re: Ca c'est fait
Yes, je veux le seul l unique exemplaire comme une hd,
c est beaucoup d' argent mais ne pas croiser la même sur un meeting c est bandant
Re: Ca c'est fait
buickestate a écrit:et bein, un petit verre de cokecola entre amis.....
yes, et puis les sieges sont confortables
Re: Ca c'est fait
maya.bz a écrit:buickestate a écrit:et bein, un petit verre de cokecola entre amis.....
connaissant les loustiques il ne devait pas y avoir que du coca dans les verres
cool pour la moquette, çà rend vraiment bien avec la console
putain le V6 fait tout petit dans le compartiment moteur
vivement un bon 350
Re: Ca c'est fait
Ah ah ah deja le gros compte tour qui va bien !!!!!!
Re: Ca c'est fait
Pontiac455ci a écrit:Ah ah ah deja le gros compte tour qui va bien !!!!!!
je deviens vieux
et j'y moins de moins en moins
Re: Ca c'est fait
C'est vrai que sa fait de sacré pasage de roue vide !!!!! Etonnant qu'i y ai de si petite roue d'origine !
Mais quelque part c'est pas plus mal au moins, comme tu dit ,tes 17' passeront bien dedans ^^ !!
Re: Ca c'est fait
lundi on sort moteur / boite
Re: Ca c'est fait
y ont qua venir nous aiderbuickestate a écrit:et les clients?
» vol mustang ' je fait suivre au cas ou , merci
» nous a la Jamaïque on fait du bobsleigh .......
Page 10 sur 19
