carbu cadillac seville
Page 3 sur 3 Précédent  1, 2, 3
carbu cadillac seville - Page 3 Empty Re: carbu cadillac seville
Message  christophe le Jeu 22 Déc - 16:38
ok merci beaucoup , et si on se revoit pas avant passer de très bonne fete Smile
christophe
christophe
Message  maya.bz le Jeu 22 Déc - 16:41
christophe a écrit:ok merci beaucoup , et si on se revoit pas avant passer de très bonne fete Smile
a toi aussi
Message  maya.bz le Jeu 22 Déc - 21:24
pas de bol je suis deja de retour
il a trouvé le boitier avec eprom 230$ livré chez toi
Ref AC Delco 88999101 qui remplace la ref ACD 1225650, ou reference Cardone 77/5650
<<< In automotive electronics, electronic control unit (ECU) is a generic term for any embedded system that controls one or more of the electrical systems or subsystems in a motor vehicle. Other terms for ECU include Electronic/Engine Control Module (ECM), Powertrain Control Module (PCM), Transmission Control Module (TCM), Brake Control Module (BCM or EBCM), Central Control Module (CCM), Cental Timing Module (CTM), General Electronic Module (GEM), Body Control Module (BCM), Suspension Control Module (SCM), control unit, or control module. Taken together, these systems are sometimes referred to as the car's computer. (Technically there is no single computer but multiple ones.) Sometimes one assembly incorporates several of the individual control modules (PCM is often both engine and transmission) Some modern motor vehicles have up to 80 ECUs. Embedded software in ECUs continue to increase in line count, complexity, and sophistication.[1] Managing the increasing complexity and number of ECUs in a vehicle has become a key challenge for original equipment manufacturers (OEMs).
Types of electronic control units
Airbag Control Unit (ACU)
Body Control Module controls door locks, electric windows, courtesy lights, etc.
Convenience Control Unit (CCU)
Door Control Unit
Engine Control Unit (ECU)_not to be confused with electronic control unit, the generic term for all these devices
Electric Power Steering Control Unit (PSCU)-Generally this will be integrated into the EPS powerpack.
Man Machine Interface (MMI)
Powertrain Control Module (PCM): Sometimes the functions of the Engine Control Unit and Transmission Control Unit are combined into a single unit called the Powertrain Control Module.
Seat Control Unit
Speed Control Unit
Telephone Control Unit (TCU)
Transmission Control Unit (TCU) >>>
In French from Google :
Dans l'électronique automobile, unité de contrôle électronique (ECU) est un terme générique pour tout système embarqué qui contrôle une ou plusieurs des systèmes électriques ou sous-systèmes dans un véhicule automobile. D'autres termes pour ECU incluent électroniques / module de commande moteur (ECM), module de commande du groupe motopropulseur (PCM), le module de contrôle de transmission (MCT), Brake Control Module (BCM ou EBCM), module de commande centrale (CCM), module de temporisation Cental (CTM) , le général Electronic Module (GEM), Body Control Module (BCM), module de commande de suspension (SMC), unité de contrôle, ou d'un module de contrôle. Pris ensemble, ces systèmes sont parfois appelés ordinateurs de la voiture. (Techniquement, il n'ya pas d'ordinateur unique, mais plusieurs.) Parfois un assemblage intègre plusieurs modules de contrôle de l'individu (PCM est souvent à la fois moteur et transmission) Certains véhicules automobiles modernes sont jusqu'à 80 calculateurs. Logiciel embarqué dans les calculateurs de continuer à augmenter en nombre de lignes, la complexité et de sophistication. [1] Gestion de la complexité croissante et le nombre de calculateurs dans un véhicule est devenu un défi majeur pour les fabricants d'équipement original (OEM).
Types d'unités de contrôle électronique
• Airbag Unité de contrôle (ACU)
• Module de contrôle de Body Control serrures, vitres électriques, éclairage de courtoisie, etc
• Unité de contrôle Commodité (CCU)
• Unité de commande de porte
• Unité de contrôle moteur (ECU) _not être confondu avec l'unité de commande électronique, le terme générique pour tous ces dispositifs
• Unité de contrôle électrique Direction assistée (PSCU)-En général, cela va être intégré dans le bloc d'EPS.
• Interface Homme Machine (IHM)
• Module de commande du groupe motopropulseur (PCM): Parfois, les fonctions de l'Unité de contrôle moteur et l'unité de contrôle de transmission sont combinés en une seule unité appelée le module de commande du groupe motopropulseur.
• Unité de contrôle du siège
• Unité de contrôle de vitesse
• Unité de contrôle de téléphone (TCU)
• Unité de contrôle de transmission (TCU)
Message  christophe le Ven 23 Déc - 13:09
salut maya je te remercie bien ! on dois-je envoyer l'argent ? si il possède bien les deux proms , aucun problème je le prend Smile
christophe
christophe
Message  christophe le Ven 23 Déc - 13:21
désoler du double poste , voici une photo , je peut en remettre d'autre si vous le voulez ^^'
carbu cadillac seville - Page 3 Cadill10
christophe
christophe
Message  maya.bz le Ven 23 Déc - 14:13
christophe a écrit:salut maya je te remercie bien ! on dois-je envoyer l'argent ? si il possède bien les deux proms , aucun problème je le prend Smile
Le règlement se fait à moi et je transfert
Avec ton adresse
Message  christophe le Ven 23 Déc - 15:03
oki , envoie moi ton adresse par messagerie , et je t'enverrais le réglement Smile ses bien 230$ ?
christophe
christophe
Message  maya.bz le Ven 23 Déc - 15:19
Mp
Message  christophe le Mar 3 Jan - 12:01
bonjour a tous , je vous souhaite juste une très bonne année et bonne santé. bye
christophe
christophe
Message  maya.bz le Ven 6 Jan - 17:52
t'inquiete pas
on ta pas oublier Wink
Message  maya.bz le Sam 28 Jan - 13:06
c'est bon on en a trouver, identique avec les proms pour ta cad carbu cadillac seville - Page 3 915631
Message  maya.bz le Jeu 23 Fév - 21:19
problème résolu carbu cadillac seville - Page 3 615 carbu cadillac seville - Page 3 498194 carbu cadillac seville - Page 3 319429
